I have been browsing places like barnstormers for a while to get an idea what good (or possibly good) cores are running.
I seem to be seeing that 0-or IO-360 cores seem to be out of sight-----8-10K for an "as-is" prop strike high time motor----
more for a mid time prop strike. I see some of the lesser-in-demand motors are less than half that for the same general condition.
I am guessing that all the RV builders who need motors have driven up the prices of the 320's and 360's.
I WAS thinking that a IO-360 with high compression pistons making 200 hp might be a good selection for the 4 place.
less weight than the 540 but part of the way there in HP. But it looks like the chances of finding a reasonably priced core may be
small. (this sounds like a partial clone of Lycoming's experimental version)
I have also heard of some converting lycoming -360 's to 390's by using over bore pistons + cylinders. It appears that gets to
about 200HP with standard compression.
If I dont use an O-360 or IO-360 Lyc. core---- there seems to be little middle ground- in terms of weight- between that and the lyc. 540.
There is the cont. 360 which could put out 210 hp---- but is weighs all most as much as the Lyc. 540. Plus it has the more difficult
engine mount design. (or at least -- less common--) (If I build the mount myself anyway-- is that any problem ?) I read somewhere that
the Cont. 360 cores were way less than the Lyc. 360's --- but when I have been looking -- they appear to be just as expensive........ (?)
I wonder if it could be possible to find a prop strike 360---- and get it before the insurance company can buy it from the owner as part of the settlement ? I am guessing that maybe the insurance companies wouldnt pay the claim if the owner sell any parts beforehand. ????
I would guess that the insurance company is effectively purchasing the hull from the owner- and they might decline if it was not intact ?
Of coarse you might luck out and be there when an un-insured plane groundloops---- but that would be improbable I suspect....
I expect lots of you have traveled down this road before...... if you all have any ideas. I could also just collect individual parts
as well---but I wouldnt expect that would be any price advantage over a complete core. and with a complete core-- you know everything
is compatible. (there are so many variations of the 360 )
Tim
Tim
