We attended a Bearhawk fly-away last week, and while returning home over water between the islands experienced a loss of engine power. We made a precautionary landing and discovered 3 cylinder studs had sheared off above the #4 cylinder. Several of the remaining ones were loose.
My reason for mentioning it here is that with the benefit of hindsight there were some early warning signs that I had missed, and that knowledge might benefit others. It's not a Bearhawk specific issue, but rather an engine issue. Mine is an IO540 that was rebuilt specifically for my Bearhawk.
It now appears that the sequence of events was that the studs probably sheared some time earlier, resulting in a small oil leak. We subsequently also found the left exhaust cracked through in several places.
The final straw was actually the spark plugs failing on the affected cylinder with accompanying rough running, power loss, CHT & EGT indications decreased abruptly as the precursor to the precautionary landing.
Several studs were also found to be loose on other cylinders, so we will be checking all of them and torquing to Lycoming specs.
Next time I'll be paying more attention to any oil leaks no matter how small, and also casting an eye over those cylinder nuts which are visible.
90 minutes earlier in the flight, unaware of the issue.
Flight track from Gisborne across Hawkes Bay and Cook Strait. We landed at Kaikoura on the east coast of the South Island.
