Update:
I fix aircraft for my day job, so I'm always keen to break the rules and make up my own steps when I come home to work on the bearhawk :-)
For those of you who fit a AN5812-type Dynon pitot probe, they talk about tapping and drilling a #6 screw to hold the probe into the mount.
I thought this sounded like lots of work, so I mixed up some 2-pack adhesive (I used 3M brand 2216), and glued it in.
Then I through-drilled two 3/32 holes either side of the pitot tubes, and put in a couple of spring/roll pins.
Measure the width of the probe over the holes, and grind down the roll pin to sit just under-flush.
I sealed the hole with more adhesive.
I'd be surprised if the probe ever fell out, at the grandpa speeds I intend to fly! :-)
James
James
