Has anyone explored the possibility of installing a skylight without welding, maybe a floating frame, aluminum or cellulose acetate butyrate resin. To be cemented to fabric like an inspection plate ring. Lexus lense. Simplicity and light weight is the goal. The picture for the shape not the supporting structure. Thanks
Skylight
Looks nice, trying to figure out how you terminated the fabric at the rear spar area. There must be a structure that spans from the sides of the fuselage to the stringers and in between the two. I have an early kit, the stringer set up is quite different. Any suggestions appreciated.You do not have permission to view this gallery.
This gallery has 4 photos.
Well, I do not have photos but here is a clumsy description.
Created a welded truss made from 1/2 x .035 square tube. The truss goes above the rear spar carry through
from sides up to stringer attach points, between the stringers, down to the other side and back across the top of the carry through. This “bridge truss†member
is then placed in front of and up against the stringer uprights. Secure with bare Adel clamps, lock wire wraps, strapping, Dutchman clamps or ??????
Just make it solid and fair to the stringers and fabric line. I placed some tabs facing aft to screw the aluminum to. See previous photos.
The top fuselage covering terminated on the truss and then additional fabric was run from the truss to rear spar carry through. You will need to make some Z clips to attach the aluminum skin sandwich to the going forward stringers.
It was a bit of a PITA to form the joggles in the lower interior piece to create the recess for the plexi.
But in the end all finished out I am very pleased.
hope that helps
Kevin D
Finished version less the aileron pulley covers. Is finished using 0.028†kydex. 0.025†2024T3 wing root covers with headset jacks..
Kevin;
The outside and inside pieces of aluminum for your skylight are each made out of a single sheet of aluminum, and put a joggle (recess) all the way around the inside piece to capture the plexiglass? That last step might be a bit beyond my current metal working skills, but the result sure looks nice.
Here's what I did... I lowered the "Hump" stringers to be level with the outside stringers. Then I welded tabs at station D and filled the span with aluminum angles to receive the fabric from the rear, and will attach the rear of the skylight. Here's the entire write up: https://bearhawk4place.blogspot.com/...-skylight.htmlOriginally posted by lamarglobe View PostLooks nice, trying to figure out how you terminated the fabric at the rear spar area. There must be a structure that spans from the sides of the fuselage to the stringers and in between the two. I have an early kit, the stringer set up is quite different. Any suggestions appreciated.
This gallery has 1 photos.Rob Caldwell
