I'm planning to run Van's conduit for wiring to the wingtips. Is it acceptable to secure it to the ribs with plastic cable ties? How about pitot/AoA tubing - must it run through grommets or can it run though lightening holes in ribs and secured with cable ties? I don't want to be cheap or unsafe (well, maybe cheap ...) but lightweight and simple seems desirable. Thanks.
Are plastic cable ties acceptable?
In my opinion I would only use cable ties in an area where they can be easily inspected and replaced. Plastics tend to dry and become brittle. They can also vibrate against a surface and cause wear. I would opt for cushion clamps.
OK, I'll avoid plastic cable ties. I started by referring to AC 43.13, and saw descriptions of bundling wires. I was preparing to do that, but noticed that many folks on this forum are installing conduit, and conduit also seems to be the standard in the RV world.
I see no problem running in a conduit but for additional weight. If I am running a small number of wires I would organize them neatly and tie them with waxed cord about every 8 - 10 inches. A small bundle I would run in a grommet in the rib. For a larger bundle I would rivet a small aluminum angle on the rib and run the bundle through a cushion clamp fastened to the angle bracket.
I just ran them through grommets in the nose ribs and used Thomas & Betts Ty-Rap TY23M 4in. Milspec and they hold for years. They are not the same as the Home Depot or Horror Freight wraps...save those for wiring utility trailers and such. Used them on military aircraft all the time. AS sells them: https://www.aircraftspruce.com/catal...-cableties.php
I don’t know if I’d trust the standard cheapo HF/Big Box tie wraps a for much on my plane. I did buy some of these which are great and designed by experimental builders for aircraft. They have a silicone lining inside and are reusable. Expensive though...
https://www.amazon.com/GRIPLOCKTIES-...-1-spons&psc=1
