I am talking to Hartzell's technical staff about using the Trailblazer with my Lycoming O-360 on my Patrol project. I am planning on using two E-Mags for ignition. According to Hartzell the Trailblazer prop is not approved on an O-360 with dual E-mags because it has not been tested. It is not disapproved for any particular reason either. Is anyone running this combination of engine & prop. I suppose I could fall back to a single mag and one E-Mag like on a certified engine but that would be looking backwards.
Hartzell Trailblazer Question
That’s a question that I never thought to ask either, but I’ve got an IO540 and dual EMags. I guess this is where the “experimental†in experimental category kicks in.Nev Bailey
I would call that a disclaimer, like Mcdonalds warning about hot coffee being spilled on your nether regions. They are correct in putting that out there, but composite props have much less problems with torsional vibrations that metal props. Metal props are extremely prone to it, and after a few accidents they will put limitations on them with certain engine/prop/counterweight/airframe combinations.
Composite props dampen vibrations naturally. Electronic ignition can change (depending on the timing) the power pulse and that is user definable, so no way for Hartzell or MT to test every combination.
It's also only certified for engines up to something like 9:1 compression. I'm running 10:1 compression and dual P-mags. Over 300 hours and no issues so far. I asked the same questions before I ordered my Trailblazer and they guy I talked to at Hartzell said it simply means it hasn't been tested in these configurations so you would be truly experimental. I also set my prop governor for a max rpm of 2770, by my rough math that has the tip speeds just under mach. Time will tell but as smoothly as the thing runs I don't expect any issues with the prop.Rollie VanDorn
Findlay, OH
Patrol Quick Build
I'd be very confident you would have no issues with dual p-mags. The potential issue is a sharper power pulse from the better ignition of electronic ignition.
Originally posted by svyolo View PostI would call that a disclaimer, like Mcdonalds warning about hot coffee being spilled on your nether regions. They are correct in putting that out there, but composite props have much less problems with torsional vibrations that metal props. Metal props are extremely prone to it, and after a few accidents they will put limitations on them with certain engine/prop/counterweight/airframe combinations.
Sorry TLDR. Hollow or foam core composite props may or may not naturally dampen vibrations. MT props do dampen vibrations because they have a wood core; it is the wood doing the work.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
Originally posted by spinningwrench View PostI am talking to Hartzell's technical staff about using the Trailblazer with my Lycoming O-360 on my Patrol project. I am planning on using two E-Mags for ignition. According to Hartzell the Trailblazer prop is not approved on an O-360 with dual E-mags because it has not been tested. It is not disapproved for any particular reason either. Is anyone running this combination of engine & prop. I suppose I could fall back to a single mag and one E-Mag like on a certified engine but that would be looking backwards.
