I sometimes feel that some people just hate change, no matter how badly it is needed. The DeltaHawk is rated at 180 hp, so the immediate jump to an O-360 and look for all the ways it falls short. ...and from that crew, not a single mention of how the O-360 falls short compared to the DeltaHawk. Most of what I'm going to say has been said, but I'm hoping to put some of it in perspective.
For the nay sayers:
- Yes, it is new and unproven
- Yes, it is 100 lbs (or what ever) heavier than an O-360
- Yes, there is a history of failed new engines
- Yes, there is a history of failed new diesel engines
- Yes, it will be expensive
....but do you really want this to fail? I'm not asking if you're ready to pony up your own money. I'm only asking if you want it to fail? Are you trying to ensure that there is no advancement in aircraft engines? There were many failures before the Wright bothers succeeded. It takes time and effort. Before success, there is always failure.
Now the rebuttal (points almost all already stated):
- Every engineered object is unproven before it is proven
- There are MANY Bearhawks that are carrying around an extra 100 lbs and are still fantastic airplanes!
- This engine will have a fuel burn of 10-20%(?) less than an Lycoming
- For a given range, you will depart with less fuel. That is weight savings (even accounting for the higher density of Jet-A)
- Over the life of the engine, you will save money on fuel
- As soon as you are at a density altitude of 1 foot, the DeltaHawk is making more power than an O-360
- Keep climbing, and it will be making more power than an O-540!
- Limited performance isn't a problem at sea level, it is a concern at higher density altitudes. ...unless your Bearhawk is powered by a DeltaHawk
As for the thought that the DeltaHawk is not acceptable for a Bearhawk Five: I disagree. A Five _CAN_ be built lighter than many (most?) 4's are actually built. They operate just fine on a O-360. A 540 powered Bearhawk 4 takes off with load at a density altitude of 5-8 thousand feet with a ground roll of 600-1000 feet just fine. Tell me why a DeltaHawk powered Bearhawk Five won't fly and won't outperform the O-540 powered Five when the thousands of feet get into the double digits?
...and the best part? If they are successful and come out with a 300+ HP DeltaHawk, its going to be awesome!
My current project will be an IO-540. ...but I'm cheering for the DeltaHawk.
For the nay sayers:
