Many years ago I flew a Skydiving aircraft. We were taught to descend with the power at 20"/2000RPM, and a spiral descent in order to prevent shock cooling. I never had any issues with cylinders cracking etc.
Recently I've read a couple of articles that challenge the advice I was given all those years ago. Here's one such ARTICLE. Dynon also used to include a shock cooling alarm on their displays. The newer displays don't have it, and the reason given is that the engine manufacturers don't consider shock cooling to be an issue.
So with my attempts to further control Cylinder Head temperatures, I got to wondering.......WHY. Am I chasing a unicorn ?? If I can already keep the CHT's from exceeding 205c during normal operations, and 215c on an extended warm climb, do I need to be worried about them running cooler ? Typically in a cruise they're around 160-190c anyway.
Lycoming's position on the topic is :
At all times, caution must be taken not to shock cool the cylinders. The recommended maximum temperature change should not exceed 50F (10c) per minute.
