This is related to forward mounted governor on Lyc YIO-360. Wanted to hear thoughts on setting up cable for my MT prop governor as is depicted in the Showplanes webstore. What I don't know is during setup for cable is how much the control lever arm actually needs to rotate/travel. Is it stop-to-stop (high-to-low) rpm stops? Looks like I can do it with some minor adjustment to the control lever arm position and the fuel injector line. My initial fit test is shown in the pic with the bracket not mounted to the governor, control lever arm holding against the high rpm stop screw and and with adjustment to the fuel injector line. Open to all thoughts and ideas. Hope the question is clear. Anyone else do something similar, if so, can you post a pic?
