Finally able to start my project! First step is to turn mylar drawing #4 into a template.
I didn’t like the idea of gluing down the mylar and cutting it out: I want to preserve it instead.
And I didn’t like the idea of cutting to the inside of the line: once the line disappears I don’t know where I am.
Took the mylar to a reprographics shop and had it scanned.
At home, I took the scan into Photoshop and turned the single outside line into a double line, easy to do.
The inside of the two new lines represents the inside of the original line.
Now I have a line I can cut just to the edge of, leaving that reference line visible.
Printing full size was problematic so I ended by printing at home and splicing the pages.
A slight pain but it gave me the advantage of aligning to the mylar drawing more easily.
When everything was aligned I taped and spliced onto half-inch MDF.
I cut the paper drawing free of the board and was ready to apply spray adhesive.
In my first attempt I sprayed adhesive onto the paper and struggled to lay it down properly.
In the second attempt I sprayed the adhesive onto the board instead, masking off non-spray areas.
Also made a jig which would suspend the drawing above the board, allowing for easier application.
The mylar on top of the glued drawing matches well and confirms alignment.
Then used the jig saw to rough cut the piece close to the lines.
Replaced the 80 grit with 120 grit on the disc sander, but the soft MDF is removed very quickly at 1750 rpm.
Used the disc sander in this way to get close to the line.
But it was by turning the motor OFF and using the disc sander manually was able to refine the edge.
Turning the disc with my thumb and sliding the piece on the work table made minute adjustments easy.
A bright light helps a lot as well as supporting the ends of the piece.
Repeatedly laying it on top of the mylar drawing and taking it back to the disc sander did the trick.
Now I have a template which matches the mylar drawing just to the inside of the line.
Yay!
