I decided to cut and flange the rear spar lightening holes before drilling for cap strips. Cutting the .032 holes with the fly cutter is actually a little smoother than cutting thinner material. But flanging the holes is more difficult in that the distortion is greater than with thinner material.
The result is a longitudinal bow and a transverse (up/down) bow. I'm not too concerned with the long bow, it's about 1/4 inch and requires very little pressure to flatten, so I think it can be handled in the assembly. The transfers bow was easily corrected with pliers. I used heavy tape on the jaws to protect the aluminum. My bob sticks were pretty worn out and the .032 just caused the wood to split.
My method of flanging the holes is pretty lightweight. I re-used a MDF die from the ribs and made a form block sandwich. Dressing the business edge of the die with sandpaper and cold beeswax between each hole helped a lot. The method works okay but in addition to the bowing distortion, pressing the flange also tends to cause the spar flanges to widen a bit at each lightening hole.
So, while the rear spar bends remained straight the edges of the spar flanges needed some correction to get back to 12 and 90 degrees. This was easily done with clamping and light hits from a dead-blow hammer.
With the main spars I am taking a different approach. Since those lightening holes will not be flanged, I don't expect any distortion. So I will drill cap strips first and cut lightening holes after. I am laying out the man spar with all cap strips on one side (rear) using strings, clamps and gauges to establish straightness and center-to-center distances. And I made a drill guide to use with a six inch bit which tested great and will make straight and perpendicular holes.
