I saw the article about Wayne W. working with Bob to develop an engine mount for a Corvair Engine. Bob used a 200. What are other possible engine options being considered? Is it offensive to anyone to suggest a Rotax 912?
LSA Engine Options
Bob has sid that a Rotax would be a viable option for the LSA. Basically anything that produces about 100 HP is fine.
Eric, Thanks for the reply. Someone here locally has a nice Corvair for sale that I was considering as an option, but it's hard to argue with 100 hp and 40 pounds less than the 200 on paper. I'm sure there would be some CG issues to be addressed.
I noticed that you are not very far from my location. I hope we can meet soon to discuss your Bearhawk build.
Ray J. Pierce - Raceland, LA
Anytime you are in the area, give me a call. Respond to me via private message and will give you my cell number.
Eric, I suggest any thoughts of an engine with less weight than a 0-200 be carefully considered as I think the weight and balance will be way off on the LSA. I've calculated the numbers and even the 0-200 may be marginal as presently configured. Thanks Stinger
I wonder what Barrow's thoughts on this are.
I seem to recall not long ago he traveled to a LSA builder by the name of Rollie's shop who was going to use a Corvair engine in a quick build LSA.
Barrows went to check out a factory built fuselage and at the same time Corvair guru Wynn was meeting him there to take measurements for an engine mount.John Massaro
Plans Building LSA - 091
Arizona
I know Bob tends to adust the engine position and cowling length to get the CG correct. Within limits you can account for lighter engines by positioning the engine further forward when you build your engine mount. Of course you would need to calculate how much is needed, but Bob would probably be willing to assist you with caculating that.
Hi Eric, I know for sure that Bob and William Wynn did collaborate on the corvair engine mount for the LSA and all the weight balance was taken into consideration when the mount was designed and it is build by William Wynn and Dan Wessman. I have one of their mounts and it has excellent welds ad it is powder coated. Check out these url;s https://flycorvair.net/2013/09/30/be...n-development/ , https://flycorvair.net/?s=bearhawk+LSA+mount. I think you will find it interesting.
Heres the best article on the LSA on Williams web site, https://flycorvair.net/2013/10/04/co...-bearhawk-lsa/
