Anyone trying to fit a lycoming 540 in the Patrol yet !!
540 Patrol
From a STOL perspective:
The 4-pl machine already takes off faster than it needs to, with power:weight of 260:1500 empty. That's about the same ratio as a 180hp engine in the Patrol.
Slower stall speed / shorter stopping distance would be the best improvement to either of the designs... IMHO
Extra weight would be counter-productive to the design, in that regard.Last edited by Battson; 04-16-2015, 10:54 PM.
That's 140kts/165mph. I wonder why the Patrol isn't more coveted by the experimental Super Cub community.
The Texas STOL Round-up competition, and Valdez should expand their contest beyond the Takeoff and Landing competition. It would be interesting to include a static pull contest (with Prop and Engine reps their showing off their products) and a two cross country events, one that demonstrats an aircrafts speed (an air race) and a Navigation Event that proves a designs efficiency (flown over a predetermined course at a set speed, like 100 mph, and measuring each aircrafts fuel consumption while judging a pilots ability to accurately hit course turn points at set times.)
Might as well add a Take-off and Landing with 300 pounds of Ballast.Brooks Cone
Some "Cubs" can't maintain 100 mph, and for most of them, it's not an ideal "efficiency" cruising speed... But still an interesting concept, if modified to just evaluate "most efficient" in terms of mpg (with or without speed factored in somehow).Originally posted by Bcone1381 View PostThe Texas STOL Round-up competition, and Valdez should expand their contest beyond the Takeoff and Landing competition. It would be interesting to include a static pull contest (with Prop and Engine reps their showing off their products) and a two cross country events, one that demonstrats an aircrafts speed (an air race) and a Navigation Event that proves a designs efficiency (flown over a predetermined course at a set speed, like 100 mph, and measuring each aircrafts fuel consumption while judging a pilots ability to accurately hit course turn points at set times.)Jim Parker
The Valdez competition puts all experimental aircraft in the same category, so it's dominated by purpose built aircraft these days. Nitros injected monsters with oversized wings, flaps and ridiculous long landing gear. Plus, the cub isn't so much about performance anymore, it's more of a cult following. If you suggest that anything might be a better STOL bush plane, you're obviously an idiot or crazy.Originally posted by Bcone1381 View PostThat's 140kts/165mph. I wonder why the Patrol isn't more coveted by the experimental Super Cub community.
Coincidently, the Bush Class at Valdez originally did have a round with 300lbs of cargo, in addition to the empty rounds. I don't know if they still do that.Phil Schaefer
Patrol #073
Working on Spars
