Opposite hand
  • Opposite hand
    Finished my second rear spar today. I'm stoked. On to the front spars. All details are fabricated. Just need fastening. Whoever said " no matter what, keep moving forward" got it right.
    Gerry
    Patrol #30
    100% I will cheerlead you on!
      Here's some pictures of the finished rear spars. Still need a little touch up paint on the rivets but they're ready for wing panel final assembly. Primer is Stits.
      Gerry
      Patrol #30
      This gallery has 5 photos.
      • davzLSA
        davzLSA commented
        like that color
      You need some angles brackets on the rear of the rear spar for the pocket ribs.
      Stan
      Austin Tx
        looking good!
          You mean these. I did leave off the most inbd cove rib attach angles because I'm not exactly sure of their inbd/outbd location. When I finalize the the flap and aileron spars then I'll know for sure.
          Gerry
          Patrol #30
          • sjt
            sjt commented
            On mine I put my wing tip bracket a little closer to the end so that rivets can be driven thru pocket rib into the wing tip rib.   I do not think there is anything in the drawing. I was following Eric Newton's manual.
            sjt p284
