Bergy, Thanks for the program!   I am starting to believe that scales in a workshop will improve results of every aircraft.  I also ought to plan my empty wt and CG, and know where I stand as I build rather than arrive at it by accident after everything is done.
Chris and Rollie, One factor that I am familiar with and may contribute to the slope is elevator effectiveness at slow speeds.
The quantitative element of the the slope on the forward end of the envelope may be the elevator's inability to provide pitch authority at a slow speed (the landing flare) while operating at a forward CG. Forward of the line, I am guessing that the aft stop on the elevator will be contacted during the landing flare.
I flew a Beech 56TC Baron once upon a time....the very large engine that Beech could put on this four place Baron fuselage moved the CG forward. (Lyc TSIO-541, 380 hp, 46" MAP on takeoff) With one 150 pound pilot and no freight, it required 50lb. ballast in the aft most baggage area to be in the CG envelope. If not, one would be forward of the CG limit, and hit the aft elevator stop during the landing flare resulting in a near three point landing.
The Flight Test Phase is the time to test this stuff. We can find out "How heavy and how far forward can the CG be and still have satisfactory elevator authority?" I suspect that the Patrol with a carefully targeted empty weight CG is so well designed that the elevator never looses effectiveness in the flare.
