Hi Guys,
Thought I would give you Canadians some info on trouble I ran into with MDRA during my final inspection of my Patrol. the Items are
1) Cables cannot deviate from straight more than 3 deg. I had to relocate my trim eyelets aswell as weld in Pulley's for the rudder cables ( this sucked).
2) If you use a rubber connection on your fuel lines in the wing root, you will need to "seal off" the wing root and fuel line so that if the rubber connection leaks, it won't run down the fuel line and enter the cabin
3) Need alternate air in the event of air filter icing
4) must ground the fuel tanks to the airframe
5) Baggage area tie downs have to be installed
I had items 3,4 and 5 done but wanted to mention them for others
Now I wait for paperwork. The sleepless nights continue,
