I noticed a general preference for the clip lock turnbuckles. There is plenty of info how to do the substitution for the 4P but not for the Patrol.
This is the list I have for the standard safety wire turnbuckles:
I then followed the ACS guide for substitution and came up with:
The issue I ran into is with the min breaking strength. The Patrol requires 2200 lb apart from the trim cable. The specs for the clip-lock components are either 1600 lb or 3200 lb. Is there any reason the 3200 lb components would not work? Is there enough space for slightly bigger turnbuckles in the Patrol? How about the forks? Do the size 5 forks (as used in the 4P) work?
