I am 100h into the Patrol build and working on the floor panels. This part seems to be fairly straight forward but also full of little details that might matter later. If any of you have some recommendations and things to look out for I would be happy to hear them.
Some questions that I ran into:
​​​​How should the panels overlap? This determines which panels are easiest to remove. I was thinking if I have the panel under the front stick and under the rear seat on top for easy removability.
What are the the threads under the rear seat in the fuselage frame for? Seat belt attachment points?
What is this relieve for?
I would probably not even have noticed it if it wasn't for the arrow.
Finally the panels have old tape on the front and old protective foil on the back. Never seen something so hard to remove. I have tried anything from acetone, IPA, WD40, plastic scraper, to angle grinder. Anybody knows something that's working well to clean up the surface?
