DBeaulieu
Patrol Q/B Kit #79
1/4" hole centered on fairlead tube center outboard of the wing root. Aileron cable will pass thru this similar to the yellow string. Does this need to be drilled to a larger diameter. I'm thinking the fairlead will keep the cable centered unless there is a significant direction change as the cable goes to the fuselage
