I think i am abut to order plans - but dang-it ..... which ones.....
My initial thoughts were that the 4 seat would be just about as easy/hard to build as the 2 place.... which I continue to believe. Fuel consumption seems just about
Identical (at same speed) So it just seems to come down to how many seat and how it flies. I don't want a single seat- so 2 seats is OK and maybe 4 should be good too.
As far as flying goes- I see that the patrol has a thicker wing planform and a flying horizontal stab- where the 4 seat has a slightly thinner wing and a horizontal with no profile( just tubes)
I notice that this seems to give the 4 seater a slightly higher cruse speed and adds 5 knots to the stall speed. I would GUESS the the patrol's thick stab might require less trim input to
counter power changes....... (?)
I guess what I am asking is what would I FEEL different between the two if I could fly them blindfolded (so to speak) (as well as take off and landing)
The only other difference I can see is the empty weight being a little higher on the 4 seater...... (which I would suspect might be due to the bigger engine more than the extra tubing)
Any thoughts to help me decide ?????
(I should be able to start making ribs once I get the plans- :-) )
( I have been helping my cousin restore his 1934 Fairchild 24 - and I think I can build one from scratch as easy as I could do what he has done..... in terms of man hours anyway ..)
( his plane will just about be a museum piece though...)
Tim
Tim
I don't think you can go wrong with either choice.
