I thought some might find this interesting, so I'll share for "geek" leaning Bearhawk flyers out there. I'm a novice at this stuff so claim ignorance may be involved.
My New Year's resolutions were to:
- Improve the consistency of my landings and landing distances
- Learn something new
A little background:
I participate in backcountry flying in all the wonderful places like New Mexico, Arizona, Utah, Idaho, and Oregon. Truly living the dream! I concentrate totally on backcountry techniques and always trying to improve skills. That said, this is backcountry oriented and not intended for GA flying. They are two different worlds and require different skillsets, commitment, and approaches.
At Mexican Mountain, last fall.
So the goal is STOL and landing short. I had migrated to some bad habits in the quest for super short landings. Short version - pretty slow, steep approaches that would require some pretty "perfect" timing and skills to "land on the wire". I would hit a 230 landing distance then the next try would be a 825 distance. It was frustrating me and I couldn't get it right every time. I had no consistency. That 825 meant that the shortest strip my personal limitations (2 x longest) would put strips shorter than 1650 out of consideration. that sucked!!! So giving up on participating in STOL contest and going for consistent, short landings. Don't have a spare airplane in the barn if I bend or break this one!
The learn something new thing? Some people learn a foreign language as a brain exercise. My version of that is to learn Excel which is truly a foreign language.
So I am starting over. First step, define and improve my approaches with should result in more consistent landings.
Second step is develop tools that are easy to use to evaluate those approaches and landings. That is where the Excel comes in and makes this truly a project!!! I truly wish my project was a new LSA kit but time and money (AVGAS
) won't allow that.
So attached you will see my first attempts at starting over. Go and determine new glideslopes and sight pictures to improve approaches. see the attachment
Can't explain the difference on the 1600 RPM graph. I did move to a different spot to give a friend some room for his acro box. Closer to the mountains which may a have a different "mechanical" lift going on. The blue line on that graph was the expectation.
What I learned:
Peace, Fly Safe
What I learned:
- I need to work and concentrate on controlling my airspeed more. My eye sees something different than what the data reveals. I have a knack for only visually scanning my AS when it is on or very near 50.
- If these calculated glide slopes are correct that means I had migrated to a pattern of very steep approaches in excess of 10 degrees. That may explain the "bird landing on the wire" inconsistency I was experiencing.
- I included the average pitch and descent rates. The are simple averages of both passes combined. 743 FPM on the 1300 rpm???
Peace, Fly Safe
