I just made the realization last night that all of my rivet calculations were not including primer. Does anyone have a measurement the thickness of an epoxy primer or a rib coated both sides with it?
Edit: From what I have been able to find, the thickness of the primer should end up at roughly 3-5 thousandths per side depending on how it is sprayed. Since I already put in my order for rivets I will likely have some that are too short. On the bright side, it will give my helpers (my three boys) some to practice driving and I had ordered 1/4lb of the next size up of every rivet so it will not put me line-down.
