I do a lot of home improvement projects where I end up framing stuff with lumber, plywood, etc. I've fallen in love with using torx drive construction screws because the drive is just so positive-- you never skip or strip one. I use the drive bits and have a whole torx socket set and screwdriver set. They're especially nice in the micro sizes on electronics.
I'm thinking about using torx drive stainless screws for all my sheet metal fastening on the Bearhawk. I just remember days past, disassembling my Cessna inspection covers, etc and how much attention and pressure I had to apply for those screws. Wouldn't a good torx drive screw be nicer?
The only downside I can think of is that it would be easier to over-torque them since the drive is so positive, but that can be said of any fastener. A phillips just strips the drive head before you can strip the threads (usually.)
It also seems that torx are more plentiful in pan head, whereas truss head are more scarce but seem to give a nicer low-profile finish for sheet metal applications.
Alas, conversion to torx is made difficult by the availability (and rumored quality) of the fasteners themselves.
