Want to share an experience with latex paint on aircraft fabric. Few months back someone on here posted a youtube video of a guy that has been experimenting with latex. I watched it and the webinar he did for EAA and I emailed him a few times. Pretty cool guy that has gotten some really good results with latex on his airplanes.
I need to insert here: I do NOT plan on using latex on my BH. Based on my experience with it so far and my communications with Malcolm I think it would be totally fine but I'm too chicken. I just want to share my experience with those that may be interested.
Recently I did some work on my boat. Part of that work was building a new top for it. Lots of riverboaters use either hardtops (aluminum covering typically 1/8" think) or fixed frame soft tops (aluminum frame with canvas stretched and snapped in place). For weight savings I decided to go with a soft top. I thought it could be a good experience to cover the frame in ceconite but I didn't want to spend the money on real aircraft paint for this experiment so I decided to use latex. My boat lives outside so it will be a good test of the paint/fabric combo.
Here is the frame:
Untitled by Jon Whee, on Flickr
Bought some heavy uncertified fabric from ACS.
All shrunk and taped in the same fashion demonstrated in Stewart Systems youtube videos. Yes, I'm officially youtube certified for aircraft covering
Applying the Glidden Gripper primer. Here is where I screwed up. I used a regular brush instead of a foam brush so even though I dry sanded between each primer coat I couldn't get all the brush lines out. Had I used a foam brush I wouldn't have had this problem. First cross-coat needs to be brushed on to ensue the primer gets a good mechanical bond to the fabric and it needs to be thinned with 20% distilled water. Guess here is a good time to note that I didn't clean the fabric with anything. Probly should have.
After the first cross-coat we started using our graco airless paint sprayer. The paint pump is awesome and makes house projects so easy. We applied 2 more cross coats of primer (so 6 coats total). We could have stopped after the second cross coat but we weren't sure at the time.
Guess I lost the pic of us spraying the primer.
First coat of color (Sherwin Williams All Surface Enamel latex based). All color was applied using the graco paint pump.
We applied 5 coats of paint (2.5 cross coats). Again we could have stopped at two cross coats but we didn't know.
We didn't bother with wet sanding or polishing like Malcolm does so we didn't get a mirror finish like he does but we are really happy with how it turned out. It was really nice to not mess with an air system and it was unbelievably easy to get reasonable results. The only downside I've found so far is latex paint never hardens. If I wanted to I could dig my fingernail into the paint and dig out a chunk. I tried and you have to dig hard enough that it hurt my nail but I think you could get some off. Malcolm said you can touch it up with a art brush and you won't even know it was there.
If anyone wants to see some close up pics let me know an I'll try to take some. The boat has been outside for three weeks, weathered several thunder/rain storms and one Idaho hail storm (ID hailstorms are pretty light with only BB sized hail).
Also worth noting: I used 3M Fastbond 30NF adhesive for this. Malcolm said he heard it was the same as Stewarts eko bond. Amazon only had the neutral glue in the quart size an not the green/blue like Stewarts, I could have bought a gallon in the green but I didn't want to buy that much. I have limited experience with Stewarts glue but I'm almost positive this 3M glue is the same stuff.
Here is the frame:
Untitled by Jon Whee, on FlickrBought some heavy uncertified fabric from ACS.
Untitled by Jon Whee, on FlickrAll shrunk and taped in the same fashion demonstrated in Stewart Systems youtube videos. Yes, I'm officially youtube certified for aircraft covering
Untitled by Jon Whee, on FlickrApplying the Glidden Gripper primer. Here is where I screwed up. I used a regular brush instead of a foam brush so even though I dry sanded between each primer coat I couldn't get all the brush lines out. Had I used a foam brush I wouldn't have had this problem. First cross-coat needs to be brushed on to ensue the primer gets a good mechanical bond to the fabric and it needs to be thinned with 20% distilled water. Guess here is a good time to note that I didn't clean the fabric with anything. Probly should have.
Untitled by Jon Whee, on FlickrAfter the first cross-coat we started using our graco airless paint sprayer. The paint pump is awesome and makes house projects so easy. We applied 2 more cross coats of primer (so 6 coats total). We could have stopped after the second cross coat but we weren't sure at the time.
Untitled by Jon Whee, on FlickrWe applied 5 coats of paint (2.5 cross coats). Again we could have stopped at two cross coats but we didn't know.
Untitled by Jon Whee, on FlickrWe didn't bother with wet sanding or polishing like Malcolm does so we didn't get a mirror finish like he does but we are really happy with how it turned out. It was really nice to not mess with an air system and it was unbelievably easy to get reasonable results. The only downside I've found so far is latex paint never hardens. If I wanted to I could dig my fingernail into the paint and dig out a chunk. I tried and you have to dig hard enough that it hurt my nail but I think you could get some off. Malcolm said you can touch it up with a art brush and you won't even know it was there.
