Fuel Primer Line
I was taught the safest way to hand-swing is to pull the bottom blade, from about the 5 o'clock position - standing beside the plane and walking / running away from the prop as you pull. Using that technique, I think the big tires would be OK. You will see guys standing in front and pulling downwards on the prop - that is a good way to lose an arm / head. Three blade props are the worst to hand swing, especially the lighter ones like the MT (my opinion)
Swinging the prop through by hand is not too hard on the 4 cylinder engines. The six cylinder is harder and having those Bushwheels on makes it much harder still. The prop is WAY high up in the air. Mark
I guess if I had no battery power whatsoever for some reason - so little power that I couldn't run the fuel pump for a few seconds - maybe I would want a primer. That would be the worst case scenario... which would only really apply in a true "lost in the backcountry" scenario with no help available. I suppose 99 times in 100 a flat battery happens when the plane's been sitting for weeks / months, not in the middle of nowhere - unless you leave the masters on!
I would like to find out whether I can swing the engine enough to get fuel to the cylinders. To be honest I can't say if gravity plus the engine driven pump would supply fuel to the cylinders or not. I presume it would.
Leave a comment:
Originally posted by Zac Weidner
Is your pacer original with the cables and pulleys on the control column? Our '58 has a roller chain and sprockets down almost to the floor where they connect to cables.
Leave a comment:
Originally posted by Mark MoyleOn my pacer the primer line fitting is an 1/8" NPT fitting on Steve's aircraft gascolator. The gascolator is mounted to the engine side of the firewall. The primer line route is up the firewall to a penetration...then to the primer.... Just another fuel line that needs to be supported and protected from anything that it may come into contact with. The 63 year old copper line in my Pacer had quite a few areas where it had nearly rubbed through.... The only thing I don't like about Pipers primer line routing is....two lines through a grommet on the firewall.....and all the grommets were deteriorated. Perhaps consider making firewall penetrations using stainless plate and tube with fire sleeve. Anywhere a fuel line may come into contact with something....Multiple layers of heat shrink tube.
Leave a comment:
Originally posted by JimParker256Just saw a thread over on "another forum" where they discussed copper fuel lines on an older Cessna. There was an AD (many years ago) that mandated replacement of the copper fuel lines, because they have a tendency to work-harden and crack. Under pressure, they spray fuel all over the place. I believe the FAA banned them from any newly certified aircraft some time back. I plan to use something else.
Leave a comment:
Leave a comment:
I setup the firewall for dual battery boxes and I have thought that rather than a primer a mini jump battery would be good but what if...
I'm not sure why copper tube are used. I'll be using stainless steel...I think.
On the Continental IO360 there are two ports in the intake tubes that the primer feeds to.
Leave a comment:
"Why is copper tubing using for primer lines anyway? I had a copper oil pressure sender line snap on me a while back, dumped most of my oil. Isn't there a more flexible/resilient alternative?"
I've wondered the same thing. Only answer I could guess is because of the tIny little primer fittings that go into the intake ports and the little brass nipples that have to be brazed onto the lines. Because the fittings are brass, material choices are limited. I suppose one could use completely different fittings and use some sort of flex hose...
Another question has popped up, though. If the injection nozzles are in the intake ports of an injected engine, where would one put primer fittings to prime each cylinder?
Leave a comment:
Unless the battery is dead. I would like to have the option of hand propping so I'll need a primer.
But, shit does happen.
Why is copper tubing using for primer lines anyway? I had a copper oil pressure sender line snap on me a while back, dumped most of my oil. Isn't there a more flexible/resilient alternative?Last edited by Zzz; 09-07-2016, 12:45 AM.
Leave a comment:
Leave a comment:
Thanks Mark. That fitting looks like it might be a good way to do it.
I just looked up the Cessna 185 manual primer and they attached the primer line to the gascolator. I'm not sure I'm entirely comfortable with that.
Leave a comment:
Ah! Hadn't thought of that.... You can use one of these on the output port of the gascolator. https://m.summitracing.com/parts/rus-670063
Then run the 1/8 copper line to the primer with the 1/8" NPT ferrule fittings..
Sent from my iPad using TapatalkLast edited by Mark Moyle; 09-04-2016, 04:54 PM.
Leave a comment:
Leave a comment:
