Specifically the 1/4" hinge bolts in the .071 flap and aileron hinges. Apparently these holes were pre-drilled in later wing kits, mine aren't. Gives me a little more flexibility in alignment, but I wan't to make sure I maintain minimum edge distance. I'm thinking it is 1 1/2 x bolt diameter measured center of hole to edge. Have looked through AC43.13 and Tony Bingelis books without any luck.
Bolt edge distance in steel fittings.
I had some issues with edge distance with the hinges. Bob takes almost every fastener close to an edge right to the limit. I guess thats how to design and build a light airplane. In some places like the hinges, he cheats if the fastener isn't "loaded" in the direction of the edge. If I remember right, the AN3 bolts on the hinge brackets end up being too close to the edge. If you don't drill them that way, there isn't enough room to turn the head of the bolt. Ask me how I know.
Yes. I won't go into details. I take responsibility. I'm having a machinist remake some hinge angle right now for me. I recommend not doing this step until the wing is fully riveted closed so that the wing gives a stable platform to align the flight controls.
Psychology of building airplanes confirms this conclusion i heard once upon a time. Avoid letting problems build up. When you come across a problem try to solve it right away rather than set it aside. If multiple problems get set aside, then the pile can seem insurmountable and suck the enthusiasm out of the project.Brooks Cone
