I tried attaching an Adel clamp today for the first time as per the attached photo, to secure a fuel filter.
The tube I’m attaching to is 3/4 inch, and I’m using an AN742 -12 clamp which appears to be the correct size (is it ??).
However, when I tighten it, it is not completely tight on the steel tube and doesn’t hold the filter securely. What am I doing wrong? Should I be using a bare steel clamp against the steel frame tube ?
