Windshield pillar cover
svyolo
Junior Member
If it were just me, I would leave the pillars uncovered and save weight, but you want your passengers to feel comfortable. I want to cover the fuel lines and wiring going up the pillar. I was thinking two U channels, the outside one being .032 or .040, over the sides of the windscreen, and the inside being .016 or .020, just for the cover. They would share the screws and nut plates on the outside, and have a few screws and nut plates facing inboard to join them together.
Anybody do anything like that?
Hi Svtolo I was thinking the same thing, I have not found any documentation on how to do it so Im thinking its just another opportunity to exercise my creativity in scratch building. I have plenty of pictures of this but its difficult to tell exactly how things are "supposed " to go together. If you find anything please post it. I could use the info.
This is what I did, used .032 alum made 2 "U" channels one from the outside of the windshield bent 90 degrees for the door jamb and 1/2 inch bend 90 degrees to capture the inner piece and all held in place by the 3 screws holding the windshields in place. I also used enclosed anchor nuts so as not to have any protruding screws to damage the wiring, pitot static and fuel lines.
Yes I have 3 enclosed nut plates riveted to the tabs on each side, that hold the windshield in and the cover plates so no other fasteners makes a nice clean install.
All the large commercial aircraft use it. I wonder how it burns, might try a piece and see. I’ve got a reasonable amount in my build already.
Kydex us diffucult to ignite, it will burn but without a external flame wll self extinguish. I'm curious to see what your experinents show. It will burn at temperatures in excess of 400 degrees. If its 400 degrees inside your Bearhawk you have a big problem. See Kydex.com for more flammability info.
Gerry
Patrol #30
I made up some windscreen pillars today, using Kydex. It took about 2 hours of playing around to fabricate them for a good fit. They’re also quite sturdy with most of their strength coming from the bends. I made the covers in one piece, with 5 sides by folding them around a piece of timber.
I also tried to light a piece up with the has torch. I couldn’t get it to sustain a flame. It melted and smoked a bit, but wouldn’t ignite.
I’m also planning to put nutplates on the tabs, then use machine screws through the windshield, through the Kydex, into the nutplates.
Click image for larger version  Name:	E1E29B1A-0F68-4B81-BB06-00D439024536.jpeg Views:	0 Size:	360.1 KB ID:	65190
Click image for larger version  Name:	29CFDC87-DDA7-4D29-909D-E4D638404FA1.jpeg Views:	0 Size:	266.0 KB ID:	65191
Click image for larger version  Name:	3BA191B1-FA1F-4A37-9E7B-5D4922342771.jpeg Views:	0 Size:	254.6 KB ID:	65192
Click image for larger version  Name:	565E64AA-81B1-4D4F-85DD-32F9FDA90923.jpeg Views:	0 Size:	272.2 KB ID:	65193
I have to try some of that Kydex. I made mine out of .025 and .016. The .025 Al is the outer cover that over the windscreen, bent into a U that forms the door pillar/seal. The inner one is a U that goes under the windscreen at the tabs, covers the fuel lines, and connects to the outer with 3 nut plates. The .025 ones took me a bunch of tries to get the way I wanted.
Back
Top
