I bought two used sets of Cleveland wheels for my plane. Just received new tires and tubes, so ready to install the main gear for the final time. I'm wondering how to tell if the Timken 13889 bearings are good. Visually they look fine but don't want them to be an issue. Thought I would ask before buying new bearings.
Wheel Bearings
Corrosion is the other way they fail, once it's gotten through the case hardening, I understand it's just a matter of time until they fail.
That said, a failing bearing in a low-criticality application like a wheel, will work for a long time before it totally gives up. They are also easy to monitor by jacking the plane and turning the wheel. Naturally engine bearing etc are treated very differently.
I have a failing bearing in my tailwheel now, and spares on shelf. I will replace once it gets bad enough, as a crumbling tailwheel bearing (one of two) for a wheel that only lands on grass is a non issue. I would be more caution with a main wheel.
