I’ve cut the big hole in the panel for the G3X display and am now thinking about the best way to mount the supplied flange. For those of you who have done this, did you rivet/bond the flange to the back side of the panel (improved stiffness, eliminate potential rattle) or did you make it more easily removable (easier replacement of anchor nuts, future flexibility). I’m leaning toward a more permanent attachment. also will be adding stiffeners to the back side of the panel to reduce flex since i’m mounting the ADAHRS unit on the back of the display.
Any words of wisdom from those who have done this?
Thanks
Wayne
Thanks
Wayne
