Fuel tank strap...the downside of working solo (most times)
  • Fuel tank strap...the downside of working solo (most times)
    While working with fuel tanks yesterday I noticed that one of my fuel tank straps was not bolted in at an attach point. Evidently it has been this way since I took delivery of the factory QB kit. What I find interesting is that I have had the fuel tanks out of this wing more than once over the past year and most recently the past month. When measuring and cutting the hole for the tank drain in the fuel cover panel and then checking fit, I noticed that the bung sat below level of the tank cover. This was different than on the previous wing where the bung sat proud of the cover. The difference or why, never clicked...should have been a clue something was amiss. After I inserted longer bolt and attached strap to attach point the tank now sits proper and I can accurately mark my holes for fuel outlets and fuel level lines.
    The point of recounting this is to raise awareness of potential pitfalls when working alone, (no set of 2nd or 3rd eyes) and being too focused or narrow in view when completing tasks on the build.
    Build on!
    Dave (from Maine)
    I had this happen more often than I can count during my build. When it happened, I called it a "BFO", or Blinding Flash of the Obvious!
      Wow, fuel tank attachments are done by the factory now? Not so when I got my "QB" kit...
      But I appreciate your point: another set of eyes spots things that we just don't notice.
        Speaking of fuel tank straps, how tight should they be? Do you measure torque or tension?
        • DBeaulieu
          DBeaulieu commented
          TJ_Slice Good question, I just tensioned them a few revolutions past uniformly max finger tight for now. Maybe someone can chime in before I do the permanent install.
