Fuel injection
Redhawk
Member
Has anyone converted their carbureted 540 engine to fuel injected? Curious about the process and cost…
Not a 540. But a 360. I hope others chime in about the 540. But I'll say on the 360....it was a bolt on job done by my engine builder (Bob). The bolt pattern is identical for the Bendix FI & Carburator. An engine driven fuel pump needs an accesory case to accomodate it. I've heard of some who use dual electric fuel pumps but seems uncommon.
I think the process would be remove and replace the Carb with the Servo, Install an engine driven fuel pump (~28 psi pump....carb pump is less like ~5 psi) Install the flow divider and injectors into the cylinders. Install injector lines. Install three other fuel lines. Install an electric fuel pump below your floor boards in the fuselage after the gascolator.
I encourage folks to continue to give information on the 540 and to call Airflow Performance. Don or Kyle are two I've talked to. AFP has both Bendix units they overhaul and manufacture there own new units that operate on the same principal. This conversion is the foundation of there business. I
I'm guessing north of $5000 for a new system, less for an overhauled Bendix kit.
The home page of AFP
https://airflowperformance.com/
I found their installation manual Under Manuals
I put an Airflow performance FM250 system on my 540. Price was $3000 but that was 2010 dollars so probably a meaningless number now. As far as the process, it was straightforward. AFP provides a very detailed installation/operation manual. I decided I wanted horizontal induction for a sleeker cowl and hopefully some ram air effect. That involved some nose bowl fiberglass work to accomplish. I highly recommend fuel injection, makes running lean of peak easy. Following the recommended procedure for hot starts in the Lycoming engine manual, I have never had a problem with them. I would do some research into what options are available today.
My 540 was converted by Bob - he did the fuel lines, injectors, engine driven pump. I added the fuel servo when it arrived. The cost was absorbed into the engine rebuild so unfortunately that's not much help.
Went with full SDS EFI system. Very well done system. No issues at all. I was able to recoup some of the cost by selling off the parts from the IO-580 that were eliminated or replaced. Dual Bendix mags, fuel spider, fuel pump, Avstar fuel servo were all replaced by SDS parts. Net cost probably less than $5k. It's a full return system so did need to get a full duplex fuel selector and some extra plumbing to get fuel back into the mains.
Hopefully you have "injected" cylinders. Ports on the upper side of the cylinder for FI. They can be added later. I had to do it on 2 cylinders.
BTW I love the idea of 2 electric pumps. They are 120 dollars each and this would might make hot starts less of an issue.
Yes, the engine had the original fuel spider with lines to each cylinder. Easy to swap out to the electronic fuel injectors.
I am actually considering the upgrade for my O-360 for fuel injection I'd be interested in a few more details on that as well as the realized benfits of the theoretical additional 20HP? Thanks
Most of the gains don't come from the Fuel Injection, either MFI or EFI. Both injection types allow you to tune the injection for more balanced A/F ratio. Some engines aren't too bad. My 540 isn't too bad. The required adjustments were small. Some engines are notoriously bad. O-200's and a couple versions of O-470's have that rep.
Balancing the cylinders allow you to run leaner, which can save gas. But most of the HP gains come from Electronic Ignition. EFI/MFI can balance the cylinders A/F, and this allows you to run more ignition advance. With poorly balanced cylinders, running more advance can cause detonation in 1 or more cylinders.
Balancing the cylinders on MFI requires running a series of EGT tests, and swapping injectors with slightly bigger or smaller orifices. EFI you can do it yourself, with the supplied programmer. With SDS or EFII, I can add plus or minus 10% fuel to each cylinder, in 1% increments.
Lycomings have the same HP rating whether injected or carburated. The extra power comes from running electronic ignition, AND more igntion advance.
On my 540 Lycoming I have 1 cylinder at +5%. And 3 or 4 at +-1 or 2%. It is probably close enough to run electronic ignition, with more advance, even without balancing them. I have no experience with doing this on a 360.
PMAGS have maps with more advance, as do SDS/EFII. I am not sure about Surefly, but I think they do as well.
Yep, what syvolo said above. I’ve found the same advantages, particularly being able to fine-tune the injector flows to balance the fuel/air ratios between cylinders. Google “GAMI spread” for more information on this. Once properly balanced, the engine runs beautifully lean of peak, with the added benefit of improved fuel economy. Another advantage is the elimination of carburettor icing.
The 20HP gain......An O-360-A1a engine has a different cylinder than the IO-360-A1a. All Carburated Lycoming 360 cu in engines use a parallel valve cylinder that is an older less powerful design than the Angle Valve cylinders found on an IO-360-A1a engine. The Angle Valve Cylinders are heavier.
Like svyolo said, the fuel injection does not add any horse power. The IO-360-B1a engine is a 180 horse with the same parallel valve cylinders as the O-360. So if you swap out the carb for the FI its pretty similar to that. The first Piper arrows had this engine. So did the Beech Travelair.
Screenshot 2026-11-17 at 5.03.26 PM.pngScreenshot 2026-11-17 at 5.03.33 PM.png
Injection and EFI will do more for efficiency than power. Every Cylinder in an engine may have its own mixture. Cyl 1 might run leaner than 2 or 3. When a carb engine is leaned until it first stumbles, then it stumbled because its leanest running cylinder got too lean to reliably ignite. So when it stumbles and then we richened it up a bit the 3 other cylinders are running even richer.
If fuel is $6/gallon you'll save $12,000 in fuel cost over 2000 hours of operating if you can save a gallon per hour.
I run Mechanical FI and Surefly ignition (SIM). The SIM's are selected to advance the timing at lower power. When I set the mixture just lean of peak at a low altitude, and I see about 7.1 gph, then that same engine (I believe with 85% confidence) with a carb and mags would be burning 9 gph. At LOP I'm not exhausting unburned hydrocarbons, so my Spark Plugs & exhaust valve stems are staying cleaner. When I lean agressively I do not feel a stumble, rather I feel power reduction. It keeps running smooth with less power. Combine the Electronic Ignition whose spark fires for a longer duration with Auto Plugs with a wider gap, and fuel flow improves.
I do have complaints about my Surefly during hot starts but they I praise them for cruise performance. EFI will give better control over tuning injectors. SDS is the best I think. My Bendix system has almost perfect balance at some fuel flow settings but at lower fuel flows the spread is not perfect. Meaning all the EGT's dont peak at quite the same time. This is normal for Bendix FI.
EI with more advance also allows leaner running, especially LOP. Leaner mixtures like/require more advance. Running oversquare definitely helps for the same reason. High MAP/low RPM has a lower optimum ign advance. Low MAP/high rpm likes a lot more advance.
Either Bendix MFI or EFI help you to do that better.
View attachment 102417View attachment 102418
I do have the Bob Barrow O360 with the Angle valves so I believe I have the right configuration from that standpoit?
