Hi all,
I had discussed this project with jaredyates earlier, and up to now have been hesitant to bring it up with this group. After weighing the pros and cons of doing so, given the sensitivity of the topic of modifying the trusty Bearhawk airframe, it was deemed that it would not be inappropriate in this forum given the passion we all share for the Bearhawk. So with that in mind, and because I made mention of this in an earlier thread, I'd like to announce "Project Expedition".
This plane is an adaptation of the Bearhawk that meets my "wants" in an aircraft of the type. It is not endorsed by "The Bob" in any way, but he and I had a long discussion about it at #OSH15, and he encouraged me to use his ideas and made suggestions of how he would improve it based on his experiences with the Bearhawk design. He said there is nothing as satisfying as designing, building, and flying your own aircraft, and was very supportive of this project. So here I go!
The aircraft is essentially 15% larger than the original Bearhawk 4-place in every dimension, and adapts the Patrol (2-place) Riblett GA30-413.5 airfoil to the 4-place airframe (per Bob's recommendation).
Mission:
It's not as easy as "just making it 15% bigger", of course. The entire structure is being reanalyzed (fuselage, wings, gear) and updated as appropriate. With the aid of some good math, a mechanical engineer, and our good friends Bruhn, Peery, Raymer, Niu, and others, this is an exciting project that will bring my dream plane to fruition.
The wings thread you have seen in the Patrol forum is the construction of the wings for this plane. The wing I'll be building: 2015-12-05_19-21-42.jpg
As described previously,
So that's the cat, and it's out of the bag! I'm happy to share my progress with you as the project progresses. Because it's certainly Bearhawk inspired, I believe it can live peacefully among its smaller (but no-less capable) siblings. However if anyone opposes its presence, I'm happy to let this be the last post, and you can follow its progress on Homebuilt Airplanes.
Rest assured that I love the Bearhawk, and it will always be in my heart!
Best regards,
Chris
Mission:
- Utility Plane
- Taildragger
- 3500 pounds targeted gross weight
- Metal Wing (38 feet in span, 210 ft^2 area)
- Rag and Tube Fuselage
- 4-6 places capable (but mainly 4 plus "stuff")
- Wide body and comfortable (48+ inches in the front seats)
- Rigged for 8.5+ tires, skis, floats
- 260-300+hp engine
- Riblett GA30-413.5 airfoil
- 75 inches chord
- Overall 38 feet in span
- 210 square feet wing area
- Integral tanks hold ~80 gallons total (the usual strap-in aluminum tank, extended one bay)
Best regards,
Chris
