I have my tundra tailwheel tacked in place on the fuselage. Seems to have appropriate kingpin angle with room for loading to gross weight
Stinger on 4 place
That's a great looking tailwheel! I have a Tundra Tailwheel on my Patrol and I am constantly amazed at the comments about how nice it looks. A word of note: Eric menions that the Tundra model is recommended for aircraft that will not be operated primarily from hard surfaces, because of shimmy tendancy. I can vouch for that! In my vast experience (20.4 hrs so far
), I've landed on asphalt only once. Shimmy it does!! In a couple of seconds, it shook off a steering chain. Considering how nice it works on grass, I was blown away by the intense shimmy on asphalt. I've since tightened the snubber, a bit. But haven't ventured back to the asphalt yet.
Anyone leaning towards the Tundra version should heed Eric's advice about hard surface ops.
Have you used a gopro to record any of your grass landings? That's how I found that mine would shimmy on grass too, I just didn't know about it.
Avoiding landing on the hardtop also works! But the one time I did, it shimmied. We don't have a shimmy damper installed either, but I don't think we've landing on seal in the last hundred hours, and probably never will again.Originally posted by Bdflies View PostThat's a great looking tailwheel! I have a Tundra Tailwheel on my Patrol and I am constantly amazed at the comments about how nice it looks. A word of note: Eric menions that the Tundra model is recommended for aircraft that will not be operated primarily from hard surfaces, because of shimmy tendancy. I can vouch for that! In my vast experience (20.4 hrs so far
It's only a problem at landing speeds, taxi over seal is no problem.
..... back on topic, that stinger looks good. I would be keen to hear how they perform.
I had the same issue with my factory rudder and scratch built fuselage. I ground material away just as you propose. I think there is plenty of material left but I didn't have to take off as much a you have outlined. If I'm wrong and the horn bends I'll probably cut it off and bolt on a new one.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
Simon I had the same issue on my 4 place kit. I relieved the lower stinger attach bracket as shown in the pic.You do not have permission to view this gallery.
I just confirmed with Bob that indeed the fix that Tim did relieving some material from that aft flange of the tailspring adapter is indeed the correct approach. Bob said he had designed much more material into that adapter than is really needed, and removing some material from that flange would not cause any problem.
It would seem that this is a situation effecting very few builders unless the adapter and round spring become popular with guys flying their existing planes want to swap out the tailsprings for the round one.. Mark
I had a similar problem on my 4-place too, just as a reference point.
Anyone wanting to use the increasingly popular T-3 tailwheel also has this problem.
Of course the interference was much less in my case, because the lower bracket is a different design.
It may be worth Bob changing the design of those tailwheel steering horns?
Naturally you'll be wanting to sand those cuts as round and smooth as possible, to avoid microscopic cracks initiating at the cutting and filing marks.Originally posted by SimonNicholson View PostVery similar to Tim I have removed material from the bracket. I have also taken a small amount off the steerer horn
Some people like having a steerable tailwheel. I wouldn't stay on the ground because I didn't have a steerable TW but I wouldn't purposefully build my airplane without one .Originally posted by WmilbauerWhy don't you just get rid of the steering horns and use a free castering tailwheel like the tundra liteScratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
