Thanks Bd.
Plate nuts
I found the -26 to be too long for the tunnel attach to the firewall, they run into the frame above. I tried shortening them myself but couldn't get a tip I was positive wouldn't shred the threads on the nut plates so I'll have to order shorter ones just for that. This was through 2 sheets of 0.017" thk Ti so your situation might be different.
Originally posted by Archer39J View PostI found the -26 to be too long for the tunnel attach to the firewall, they run into the frame above. I tried shortening them myself but couldn't get a tip I was positive wouldn't shred the threads on the nut plates so I'll have to order shorter ones just for that. This was through 2 sheets of 0.017" thk Ti so your situation might be different.Jim Parker
Seems like I remember that they make a special "chasing die" for cleaning up threads where you trim the bolt----- that
does not cut any of the shank as a normal die does. It might not be much--- but it might be enough to lower the friction
in the Ny-lock feature. Just a thought......
