Guys, I'm sure this horse has been beaten to death but.... As I'm deciding landing light location I'm really considering the #9 nose rib location where the flanges are opposite each other. Would anyone have any reason to say that location is not good choice??? Thanks!
Landing light location
Project Plans #1299
N1208 reserved www.facebook.com/desertbearhawk/Tags: None
Dave, I installed a wing tip light into my cherokee as a STC into the leading edge. Since there was engineering and testing involved in that STC into a wing that was not originally designed for it this could be a good reference point. The designed the STC by installing a small false spar from the wing tip rib inboard about 10". It then attached to a new partial rib that attached to the false spar and continued forward to the leading edge. This created close structure that supported the leading edge. There was also a doubler that wend under the skin about 2" wide all around. I can send you photos of the drawings and photos of the install if you are interested. I always like the idea of copying.John Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uw
Matt, can you offer some detail on this?Dave Bottita The Desert Bearhawk
Project Plans #1299
Forgot the link: http://mybearhawk.com/finish/tips5.html Eric Newton - Long Beach, MS http://mybearhawk.com
I've decided to NOT install into the leading edge. It will either be in the fiberglass wingtip or the nose bowl.Dave Bottita The Desert Bearhawk
Project Plans #1299
I enjoy flying at night and used to be of the opinion that landing lights were an necessary item even for vfr night flying. I flew for nearly ten years with semi frequent local night flight with no landing lights and didn't have a problem till this spring when I and an encounter with a taxiway lightWhen the day comes that I can build myself a BH it will have a landing light in the wingtip.
