Good morning . I have decided to convert my O360 A1F6D from the dual mag with single mount, to electronic ignition for the top plugs, and mag for lower plugs. I would like to remove the dual mag and install a single mag on the accessory case . I am looking for input as to what mag I can use here. The drive is on the left side of accessory case. Any input as always is appreciated. I was thinking S4LN 21 but really I have no idea. Thanks
Lycoming O360 dual mag to single mag
In this configuration, I was thinking that the standard practice was to go with a mag for the top plugs, and EI for the bottom plugs. Since it is assumed that the bottom plugs foul easier?Rob Caldwell
I could be wrong... Sounds like you are going with Light Speed, or SDS EFI? For some reason I thought you were referring to one of the mag drop in EI systems like Sure Fly or PMag.Rob Caldwell
D as in A1f6D is a single drive dual mag..I have a crank trigger electronic ignition now and want to use the single mag drive for a compatible single mag
not sure what mag will do the trick..I am thinking the S4LN-21? If anyone has any experience with this
