Is everyone OK with grounding battery and engine to the firewall? Also, lycoming O360, best place for ground wire location on case? Forward at starter? Or shorter run at rear of engine? Thanks all. Gary
Battery ground and engine ground location
You can see what I did here: https://bearhawk4place.blogspot.com/...al-system.html
Battery, Firewall and Engine case all together. 0 ohms.Rob Caldwell
You want them all going to your "star-point" earth, meaning that all earths for everything return to the same point. I just put a bolt through the firewall with the battery, engine earths, and a copper bus for all the avionics earths all connecting to it. A short cable from a stud on the accessory case to the firewall "star-point" is the obvious choice.
This link below is a product that complies with recommendations above. A variety of sizes are available.
