I need about a 19 1/2 inch of 1/2 inch fuel hose from gascolator to carburetor. Any suggestions at a reasonable cost . Straight 1/2 inch AN flare each end. Thanks
1/2 flexible fuel line gascolator to carb
The RV guys seem to like TS Flightlines, https://www.tsflightlines.com/contact-us.html
Be sure to add fire sleeving to your criteria for that line.
I'm in the Hose education mode today too. If you are buying the line, Jared reference is sound.
Another viewpoint......I've found on this site and from Dave Prizio's book "Powering Your Plane" (Installing a Lycoming Engine your EAB aircraft) that fabricating a hose from Aeroquip 701 hose using reusable Fittings is not hard and has significant benefits. One of them is that you are able to get a perfect fit, adapt, and change things around.
A barrier for me is Aeroquip's high cost. Failure and education is OK but lets limit the potential damage.
So, I found a simple easy to use product catalog for hoses and fittings that I linked below (Aircraft Spruce actually carries some of there hose items.) It seems that I can now educate, experiment, fit, change and perfect a hose installation for fuel and oil at a lower cost. If I have product quality issues then I am ordering the right product Aeroquip or TS Flightlines with confidence it will be right.
BTW, I believe the Phenix double braided SS hose and there full swivel compression hose ends comparable to Aeroquip 701 hose and 816 style fittings.Brooks Cone
There are quite a few different brands of fittings. A couple of dozen maybe. I bought Aeroquip first, then ended up with mostly Earls, Russell, and Summit Racings' own name brand. They are usually quite a bit cheaper than Aeroquip, and Summit is the best source for all the brands and fuel line that I have found.
I did use Aeroquip hose exclusively.
