So many factors here.
By real world are you talking about I can go here, but not there? In that case, unless you are flying on the edge of what the airplane can do, I don't think the last 30-50lbs that a diet can remove will make a huge difference.
In this video:
They mention that there is an 8kt difference in IAS between light and gross when doing the steep approach. Remembering that momentum is roughly mass * velocity, having a light airplane going 8kts slower is for sure going to matter, but that's the difference between empty and gross.....
I personally think that some weight added for bushwheels (higher AOA on takeoff and landing) and for wingtips (more wing area or effective wing area) makes sense because those changes carry there own weight and probably more, for other stuff like skylight, or seaplane doors, or nicer interior I'm willing to give up some weight because I figure having 50lbs of nice stuff or emergency gear is worth more to me than the 50ft of runway it will buy me.
Anyway to your questions, which without my bearhawk flying is pure opinion based on hearing from other builders and my experiences flying in the back country with an underpowered Cessna 170:
My opinion is that if you can swap out a heavy battery and save 20lbs, for sure do it, or if you can reduce weight by cleaning up unneeded wires/hoses, do it, but I personally wouldn't omit the skylight, or more handles, or lights, or seatbelts.
As for my 170, I do fly into one place that can get pretty tight with a 200lb passenger. So much so that I'm really thinking about how much gear I have. When I roll in there with 100lbs less, it's really a bit nicer. In my 170 it's the difference between 900ft and 800 ft and in a 1000ft strip, that means a lot. I actually prefer windy days for this strip, as you know, even a 5kt wind helps a lot.
In this video:
- Are people getting very short T/O or landing distances which a heavier Bearhawk cannot achieve? Practically are people going places they couldn't take a heavier Bearhawk?
- Are CGs in favourable locations, allowing the plane to use more of the 1,100 lbs (or even 1,300lbs take-off) useful load?
- Is there a measurable fuel economy benefit?
