I am talking to someone who has a (probably) run out (no prop strike) cont IO-470d for sale. Said it was running a year ago just before removed.
My basic thumbnail search shows about260 hP, about 426 lbs dry. thats more hP than a 540. more or less the same weight.
My question ---- i guess----- is this too heavy for a bearhawl 4 place or a patrol ? I guess the extra HP would just go into stupid high climb rate.
I have read that this approximate weight allows for full load on the baggage area . But its about 100 lbs heavier than something like an o-360.....
which it sounds like lands a bit slower due to the weight difference and maybe (?) elevator issues (?)
Sounds like not too many have used this engine. Anyone know if the 470d can have a fixed pitch prop--- and if the modern companies produce one ?
Am I right in thinking that each suffix would make a difference for props because of the different counterweight configurations ???
With the engine being that heavy - might be nice to save some nose weight. I think I read where the first 310's had fixed pitch ( is that possible ?)
and i think the pawnee had fixed pitch (but was that lyc. or cant. power-- )
i can't find information on what is different on the d suffix model. Can find suffix info for Lycoming's but not cont.
Any general thought on this whole big question mark ?
Tim B.
Tim B.
The best, safest, most cost-effective option they have is to just buy a new propeller. And that actually isn’t a ridiculous option, but it is still two to three times what I expected a simple overhaul to cost…
