Finished cutting flap ribs, although I have a few I plan to redo due to human malfunction.
Mounted the 8.50x6 tires on the wheels, and then got the wheels on the Patrol fuselage. So now it is finally sitting on its own feet! Finally able to put away the sawhorses and can move it around the shop. Still working on the brakes, but it is actually easier to work on it this way than how it was before.Jim Parker
Mounted a new steering arm on the rudder for the T3 Suspension. We've nicknamed this one the "bat wing". The bearhawk factory guys nicknamed the OEM arm the "mustache" I'm told by Mark. This is a simple modification that requires bending the mustache horizontal, then cutting off the end of the arms where they hit the spring mounting plate, then bolting on the bat wing. Tomorrow, I'll hook up the new steering system for the suspension. Not that it is needed, in fact, I find it easier to handle on the ground without steering, at least in calm winds. In a heavier taildragger like the 4-place Bearhawk, most of the steering is by differential braking anyway.You do not have permission to view this gallery.
This gallery has 3 photos.
Got to do some wood work tonight. Brent had me use some templates he made up for the airfoil wood ribs for the tail. I was transferring them and then cutting them out on a bandsaw. I think this is the only wood that will actually go into the plane.
Installed seat pans in the front seat. Although my wife liked the Husky, she wasn't fond of acces to the rear seat. Actually, no one is fond of that access. My initial selling pitch, for the Patrol, was that I could make a folding front seat back, to give much better entry/egress. Pictures attached.
BillYou do not have permission to view this gallery.
I attached the pans with MSP-42 rivets. I can't imagine why I'd ever need to remove the pans, so screws weren't necessary. Besides, the stainless rivets hold really well!
The reflection of the aluminum panels makes it hard to photograph progress. I've discarded a bunch of pictures because I can't understand what they are, even after taking them...
Yesterday, I mounted the firewall to the fuselage using nutplates and machine screws, after fitting to the engine mount holes. I did it that way in case I ever need to remove it for any reason. Also riveted the "station B" former for the tunnel into place.Jim Parker
Well, after trying to figure out how the heck that tunnel piece was going to fit between the firewall and the station B former, the light-bulb went on, and I realized I had installed the former backwards, with the flange facing forward instead of aft. Doh! I must have read those instructions a dozen times, and still misunderstood.
So I watched a video on EAA website on how to remove SS pulled rivets, and it was only about a 20-minute job to drill out the rivets, reverse the former, and re-rivet. Now the tunnel piece fits (tightly) in there and it all makes sense.
Originally posted by patrickh99Drilled more spar capstrips last night. They are now all drilled a couple sizes under. Next, attach all to the spars and finish drill, then debur. And drill all the spacers.Mark
Im almost ashamed too say this, but I took off the plastic wrap off a finished quick-build wing an riveted the the reinforcement to the fuel tank opening.
Please, no wus related remarks!!!
Wus? You've gotta be kidding! Before you fly, you're going to complete a LOT of tasks.
Now, don't get me wrong. I have ultimate respect for anyone who produces a flying aircraft, from a set of plans! But, building 51% of a plane is a big deal. And you're gonna love every minute of it!
Hey, don't apologize; taking that plastic off can be really difficult!!!
(sorry, I just could not resist! I'm jealous that I don't have QB wings)
I built rudder cables last weekend. And Monday replaced the front cables with strips made from 14ga 304 stainless. My Interstate has a similar set up and I thought it seemed a bit cleaner? Plus eliminated 2 bolts and nuts per side.
After the rudder strips/cables I started gluing the Deco Dot material down on the flooring. The front 3 pcs are installed, temporarily, the other is glued up and on the bench with plywood and weight holding it down.
I hope to soon have the fuselage on the rotisserie and start on the tunnel, boot cowl and skylight roof modification, etc., etc.
This gallery has 5 photos.
Not sure I'm going to be able to fit the intake in there without modifying the nose bowl.
Hey Jon,
Thanks for the pics. I'm a few steps behind you. I was curious re your firewall. Did you use shaped aluminum angle (5052?) for the flange on the firewall??
thanks too much
Thanks Jon. Hadn't thought about the bend past 90 deg. Makes sense when you think about the angle from the instrument panel to the nosebowl. That will help when I get there.
