  • In 1999, I had just started work on my RV-8 which I finished some 17 years later, so I get it. Life gets in the way, but what a beautiful plane you have now! Congratulations!
    • Congrats! Sounds like an “award winning “ achievement!! Actually if you take it to OSH and it’s your first time, they give you a wood plaque the is an “ perseverance “ award. When we got ours I thought somebody “gets” it! Something else they started the last few years is that they will also sing to you. Now who wouldn’t want that!? Enjoy the fruits of your labor! DnD
      • Originally posted by rodsmith View Post
        I believe I may have the unenviable record for longest time to complete a Bearhawk. But I persevered and got it done. My first build log entry was 6-1-1999. It struck me that that is a quarter century ago, somehow sounds worse than 25 years. Received my special airworthiness certificate today.
        That is amazing Rod...and congratulations! I'm really glad you stuck with it, if only to unseat me for the Red Lantern Award. Here's a blast from the past. You, me and Dan over at Dan's house for breakfast, Feb 2006 and November 2007!
        • rodsmith
          rodsmith commented
          Thanks for that Paul. Really enjoyed those breakfast meetings! Do you know if Dan is still flying his Bearhawk?
      • I really appreciate the kind thoughts expressed by so many. Most of you I haven't personally met but we are all a group of friends. Participating on this forum has certainly helped me complete my plane and helped make it a better plane. Thank you all.
        • The fuel flow test is complete and unusable fuel check was performed last week. I did a battery capacity check today and installed the Tanis Engine pre-heater. My next big goal is installing everything like cowl, fairings and what not, put the aircraft on scales. I'll also be doing a flow test on the fuel injectors. I think I'll have everything ready to download onto the FAA's portal for their inspection.
          • Congratulations Rod! I'm a slow builder too, but the success of you and others inspires me to keep pushing toward the finish line.
            • N776BE, Special Airworthiness Certificate, complete.
                Thanks, and thanks to everybody on the forum that made this possible. I would not have even attempted it if I hadn't known it existed. Special thanks to those with successfully flying BH's that continue to contribute, Mark for great customer support, and maybe the unsung hero who keeps this forum going, Jared. I did 3+ hours of training last month which with Jared which was invaluable. Highly recommended and Jared is a great instructor.
              • Redneckmech
                Redneckmech commented
                Congratulations! Now it is time to enjoy flying it!
              • alaskabearhawk
                alaskabearhawk commented
                That is fantastic....congratulations! I can't wait to see some pics and get a PIREP.
            • Congratulations another Bearhawk takes to the skys
              • Nearly complete with fabricating engine stand for the airplane engine (Lycoming YI0-360) - plan is to put factory firewall, engine mount and engine on the stand and be able to work on it in a comfortable heated garage. Might even be practicable to start fabricating the cowl after I dress the engine? Built with material I had around, except for the 1/4" plate I had to buy (ouch). It seems to be plenty beefy and very stable for storage and moving around the shop.
                • IMG_5290.jpg IMG_5292.jpg DBeaulieu I did something similar and have found it very useful to prep the engine before installing on the air-frame. I used scrap lumber I had around the farmstead and bought some casters. If I was doing it again I would raise the engine a little higher. It sure helps to be able to move the engine around. I like your clean design.
                  Roger
                  QB Companion C-9
                  N51RK
                  • DBeaulieu
                    DBeaulieu commented
                    rkennell ...That looks pretty good to me! Just finished mine up today and I think I too should have made it just a bit higher.
                • Finished engine stand today and mounted firewall and engine mount. I plan on mounting the engine next weekend. Anyone with good info on hardware and proper install technique of the engine isolators, let me hear y'all! I've got the Patrol kit dynafocal type 1 engine mount and the Lord J7402-16 isolators. Engine stand with mount.jpg
                  Cheers, (Dave from Maine)
                  • DBeaulieu
                    DBeaulieu commented
                    Ended up using AN34-6 bolts and castle nuts per Virgil's recommendation. Fit well, though I did not put the large area washer under the bolt heads
                • Got the engine out of the unheated hangar and brought it "home" for the winter to a nice climate controlled garage. Got it mounted to the engine stand and was pleasantly surprised that the engine mounted right up to the dynafocal without fuss. Now I can figure out what I've got to do to get it ready for use!
