Years ago, our flying club had a C-172 that had dual Nav/Com radios. Com1 used a belly-mounted antenna, while Com2 used an antenna mounted above the cabin (between the wings, basically). While the airplane was on the ground, Com1 was almost useless talking to Ground or Tower, but it was amazingly good in the air. Com2, on the other hand, was fine on the ground, but would occasionally receive very garbled and weak transmissions, even in the pattern. I played around in the air with it once, and found that if I changed heading by 30º, Com2 would clear up and work fine. I concluded that the issues with Com2 probably occurred when the wing was directly aligned between the antenna and the ground station, and that Com1's antenna was likewise being obstructed by the airframe while on the ground. But given my vast knowledge and experience in this area (i.e. - none at all) my logic could be complete malarky...
Antenna placement is an interesting discussion. I have concerns about stuff hanging down too far at the bottom of the fuselage, having lost a dipole transponder antenna landing in some moderately tall grass (NOT in a Bearhawk - this was a Grumman Traveler with far less ground clearance). I keep thinking that the ideal solution would be dual antennas (top and bottom), but I suspect that there are reasons it isn't generally done that way... Like maybe the two sources would interfere with each other? I should probably ask that question over on the AeroElectric forum...
