This is a fascinating topic! FAA Part 25 aircraft (airliners) have faced this same problem with Jet A. But this is a "hydraulic" issue (in physics) and the type of fuel is irrelevant.
One solution we designed into the deHaviland Dash 8 Q400 that I worked with might spark (no pun intended) some thought: the outboard "wall" of each outboard-most wing fuel tank (these were integral tanks meaning the tank walls were formed by wing ribs and spars) had a sealed-off area that the fuel tanks all vented to. This "tank", located near each wingtip, was isolated from the regular fuel tanks which are filled by single-point refueling and is known as the "Overflow Tank". The highest point (on the ground) inside this Overflow Tank is vented to ambient at the wingtip (NACA vent). At the inboard, lower edge of this Overflow Tank are some small gaps in the bottom of the rib that allow any fuel that enters to flow back out through these gaps into the fuel tank. But fuel in the fuel tank was blocked from moving outboard into the "Overflow Tank" by rubber strips, called flapper valves, covering the outlet of these gaps.
Of course, Part 25 aircraft have a refuel shutoff that prevents overfilling the fuel tanks into the Overflow Tank, but there must be at least several different methods for us to fill our BH's without overfilling them (like positioning the filler such that the limited dihedral brings the level up into the neck prior to overfilling). We do not have integral fuel tanks or single-point refueling or automatic shutoffs, etc., but the idea could still work with a small (say one-half gallon capacity) cf tank located out near the wingtip with proper venting to ambient and drain lines with check valves returning to the fuel tank(s).
