a forced landing in the winter is something that gives me the shivers...I hope this is of some use to someone out there....I have no financial interest in any of the links below...Just thinking about someone out there in the cold...trying to keep warm
I was planning on adding an extra feature to my plane that would allow myself and passengers to survive till rescue in extreme winter conditions....indefinitely(food and water taken out of equation)
It was discovered that supersoft polyurethane plastic upholstery foam has amazing properties(foam rubber and other substitutes will not work as cold weather protection) What you're sitting on could save your butt. When worn close to the skin it absorbs moisture and wicks it through the foam to the other side and dissipates it. by preventing moisture build up, 1 inch of this foam protects you to -60....essentially indefinitely.(this is claims from manufactures and users..Ive not verified this...your millage will very)
I was going to make my seats from this foam, cut them open when needed and insulate my clothes with the foam and voila...ready for the winter... waiting for rescue...many Bearhawks are probably flying now with this foam installed and didn't know its potential usefulness.
The technology has been around for awhile but to my knowledge not implemented in any way in aviation.
the blankets used in the video below use this particular foam
So you could fall through the ice and come out wet and 1 minute later be toasty warm again. A few companies are making clothing from this foam(fortress clothing in UTAH)...ect...nothing special about the clothing below in the video other then its made from this particular foam....
In my case I was also going to vacuum seal a few 4x8 sheets to use for multiple passengers...as a large sleeping bag for everyone to get into....you cover with a tarp and wait.
supersoft polyurethane plastic upholstery foam ..available in all sizes and thicknesses at very low prices..less then $75 for big sheets..from wholesale sites online ..(foam rubber and other substitutes will not work)
a good link to mother earth news with info on this.... Make Your Own Extreme-cold-weather Clothing
