I am a big fan of lace. The primary reason I like it is because there are no sharp ends to cut yourself or other wires. Also in some areas like the engine mount, wire ties can get grit under themselves and end up working like sand paper or a grinding wheel and cut through tube over time. Whenever I use wire ties over round tube, I put a piece of silicone rescue tape around the tube then use a wire tie. That solution would also work well with lace. As far as wire ties go the only ties I like are Thomas and Betts ty-raps with the metal tab. These are nylon and if they are not inside the engine compartment they will last for a long long time.
Thomas and Betts TR TY526MX Cable TIE 30LB 11" UV BL (Pack of 100) https://www.amazon.com/dp/B001DEHV36..._BSmTCbVZG9WJM
