I’ve started a new thread on this topic - there is a similar thread regarding wing root vents with a lot of good info.
My plan is to install NACA intakes on the upper boot cowl, with a short scat tube feeding 2 inch panel mounted air vents on each side of the instrument panel.
Some of you have already done this, and I see there were some reported issues where engine compartment cooling vents allowed warm air into the cold air intakes. I don’t plan to have engine compartment venting on the sides, just the standard lower outlet with a cowl flap.
Has anyone experienced rain water running down the cowl and entering the NACA ducts while parked on the ground?
If so, does it enter the pax compartment when speed increases, or does it trickle back out the way it entered as the tail comes up ?
Has anyone managed to combine both warm and cold air into the same outlet vents - similar to a car ?
Are there any other considerations I should be thinking of ?
