Is there any particular trick to painting piano hinges ? Should I paint the cowl doors separately, or attach then to the upper cowl and paint together?
Painting piano hinges
Builders Log - We build planesTags: None
If aluminum, will need to be both mechanically and chemically etched for best primer and paint adhesion.Rob Caldwell
Keep the paint on the hinge AS THIN AS POSSIBLE, and lubricate it with clear grease as soon as it's dry.
Ensure the rivetted cowl door and cowl top do not protrude into the hinge pockets.
Otherwise the paint will come off rather quickly.
- Likes 3
Thanks - just what I was after. Can you elaborate on “hinge pockets†- I don’t understand this part.Originally posted by Battson View PostKeep the paint on the hinge AS THIN AS POSSIBLE, and lubricate it with clear grease as soon as it's dry.
Otherwise the paint will come off rather quickly.Nev Bailey
I also curious about a Hinge Pocket.....hummmmm.
(Screen shot of the cowl hinge out of Bob's "Patrol Book.")
I suppose if I left the hinge bare I might avoid chipped paint look on the hinge.Brooks Cone
Each half of the hinge is made of 'male' knuckles and female pockets (which the knuckle fits into). There needs to be room for the paint "paint clearance".
You want to make sure that the cowl parts (top and door) overlap with the hinge leaves, but do not extend into the "paint clearance" area, which I have called the hinge pocket
You are trying to prevent the cowl parts from rubbing on the hinge knuckles.
Remember it all bends and flexes when you are removing and reinstalling the cowl.
- Likes 4
Air Tech Coating Fabric Tip Friday.....Piano Hinge Painting...a 1.5 minute video with Robby showing us how he does it.
