More experienced builders would probably have realized this quickly but I didn't so I decided to post this in case it saves someone some time. I spent all day adjusting, checking and re-checking my ailerons prior to finishing the cable ends. The Companion plans call for 23 degrees up and 17 down. I realized pretty quickly that I didn't have 40 in total, I had about 37. It seemed that the control stick throw was the limiting factor but I didn't think much about it and I forged ahead figuring that I would make sure I had the right ratio of up to down. It was time consuming to try to get everything perfect. Having spent a lot of time to get it optimized I then looked at the control stick and made the tiny chamfer you can see in the picture. Voila! 41+ degrees and easy to get 23/17. Definitely should have done that first!
